03 Explorer Won't Start
Old 03-09-2017, 09:14 PM
robesquibel's Avatar
Default 03 Explorer Won't Start
I have a 2003 Ford Explorer XLT. I drove to work this morning without any issues and no sign of any problems. When I got off of work, it wouldn't start. It's cranking but not turning over. I tried the fuel pump reset without success. When I turn the ignition to on, I can hear the fuel pump turn on so I don't think that's the problem. Any advice?
Old 03-10-2017, 03:06 AM
What does the anti theft light do when attempting to start the vehicle? If possible , try one of the other coded keys.
Old 03-10-2017, 10:32 AM
It's not doing anything out of the ordinary. I only have one key.
Old 03-10-2017, 04:39 PM
Next step is to check all the fuses.
Old 03-10-2017, 09:49 PM
Even though the pump runs, I'd check pressure/volume at the rail. As well as spark, but pump fails are fairly common. Prove out what it not (or is) helps to move ahead. OE pump still.?, how many miles on the clock?
You might try a 'Short shot' of ether/ starting fluid into the intake, if it fires, then look towards fuel delivery and/or power distribution issues..
birdeeshot
01-20-2006 12:28 AM
birdeeshot
01-20-2006 12:28 AM
birdeeshot
01-20-2006 12:28 AM
88 LSC
01-10-2006 08:49 PM
tonyq
09-22-2005 03:03 PM
Quick Reply: 03 Explorer Won't Start
