Washer Motor?
RE: Washer Motor?
Check for voltage at the motor connector with a test light or voltmeter, have someone else push the washer switch. Chances are you will find no voltage, these switches fail commonly. You may also have turn signal or interval wiper issues. High resistance in the switch causes inop or intermittent operation. If this is the case you will need the multi function switch.
If you find power to the motor, check the other side of the connector for a good ground. I have found several with a broken ground wire behind the washer reservoir.
unionjackbell
03-04-2013 07:14 PM
