Windows will not go down on 2002 Explorer
Old 01-02-2008, 06:08 PM
Longhorns1's Avatar
Default Windows will not go down on 2002 Explorer
All of my windows are locked. I think it is a fuse but I can't find it in the Owners Manual.What fuse is it or isit a relay????
Old 01-02-2008, 08:47 PM
Default RE: Windows will not go down on 2002 Explorer
ASSUMING IT'S NOT THE WINDOW LOCK BUTTON??
Old 01-02-2008, 09:36 PM
techmanbd's Avatar
You can download the owners manual here
https://www.fleet.ford.com/maintenan...ls/default.asp
Old 01-02-2008, 10:06 PM
it only goes back to 1996
Old 01-06-2008, 12:16 AM
I have searched for several days online. I have found what many like myself have been searching for, whickis the early model 91-94 explorer/ rangers fuse diagram, by the emergency brake.here it is:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
(look under diagram for your applicable yr and model,then clickon diagram to enlarge)
the 96 and newer are on that ford site.
Old 01-26-2008, 08:25 AM
If you can't even find your fuse how do you expect to fix a window problem. It ain't goin to happen. Check fuses, check relays, check lockout switch(at drivers location, but only locks out passenger window not driver window), check motors, check wiring harnesses, etc. When window switch is pressed do you "hear" motor trying to move the window up or down. Is this an electrical or mechanical problem. This are some of the things that need to be checked and if you can't do something as simple as locating a fuse you going to need help.
Old 01-26-2008, 09:22 AM
dude,
u need to lighten up.first off longhorn said they didn't know which fuse, not they didn't know where the fusebox is located. and so what is they don't know. that's what the ford forum is for to help others not ballbust.
Old 01-26-2008, 10:00 AM
oldtimer35's Avatar
10-4 on that one, gixxer
cakers123
11-17-2010 09:00 AM
Alex
12-04-2007 06:40 PM
kevinjohnson999
10-16-2007 11:37 AM
Quick Reply: Windows will not go down on 2002 Explorer
