Cylinder misfire!!! 2000 f 150
I have a 2000 ford f 150 with 180,000 miles. never had a problem runs great all of a sudden service engine light came on going up hill on the freeway front end seemed very shakey and power went flat.. put it on a computer and said cylinder 8 misfire anyone ever had this problem and can you help?
Hope this helps!!
I've been chasing that code myself on my 98 f150 4.6 I changed plugs wires coil and fuel injectors and the code was still showing. Finally I did Compression Test and the cylinder failed horribly.
I'd try a compression test along with the other ideas mentioned above.
Good Luck
Good Luck
