Sponsored by:
Sponsored by:
oil gauge dropped and light came on???
Old 02-15-2011, 07:44 AM
whr1966's Avatar
Default oil gauge dropped and light came on???
For anyone that can help. With my 2000 F-150 5.4L 4x4, oming to work this morning, my idiot gauge needle dropped to below the L mark and my oil light came on. I just check the oil this past sunday and it was about a quart low so I topped it off. I change the oil pretty regular but it has been several months since the last change. The motor has about 195K on it. I'm hoping that this is something simple and not expensive. Any clues where to check first?
Old 02-15-2011, 07:46 AM
whr1966's Avatar
However, after I shut it down and the started it back up, it went off???
Old 02-15-2011, 06:08 PM
way2old's Avatar
I would start with getting a mechanical gauge and watch the pressures to see what the actual pressure is. If the pressure stays within range, a common failure point is the oil pressure sending unit. If the oil pressure drops on the gauge, more than likely it is a weak fuel pump.
90tonkatoy250
07-07-2009 09:28 PM
Danny52186
11-25-2006 11:21 PM
Doyle
03-31-2006 12:18 AM
Quick Reply: oil gauge dropped and light came on???
