radiator question
radiator question
i went to the junkyard and was looking around for awhile and finally found an mid 80s to 91 f150 with a radiator i could use. it 302 like my truck, but it had a single row radiator, where mine had a 2 row. the radiator i had in my truck is wider (taller) then the single row i found at the yard, but only about a half inch. my question is, will this single row rad. work fine in my truck until i get all my other parts and get some money for an aftermarket or should i find another junker 2 row?
Yeah, best to be safe. It would probably be fine for the most part, but may run the engine a bit hot at times. And the times that it would run it a bit hot are the times you don't want it a bit hot (i.e. towing, mud, etc.).
factory310
04-28-2007 06:23 PM
