1991 Ford F150 Brakes knocking
Old May 27, 2008 | 10:37 PM
kevcoz's Avatar
Default 1991 Ford F150 Brakes knocking
I replaced the front brakes and calipers on my F-150. I am hearing a knocking noise from the drivers side wheel. It gets louder and faster as the speed increases.
The noise goes away when the brakes are applied.
Can anyone tell what is causing this?
Old May 29, 2008 | 11:36 PM
jr78's Avatar
Default RE: 1991 Ford F150 Brakes knocking
Check to see if the wheel bearings are loose but my guess is that the inner brake pad doesn't have the anti-rattle clip on it and it is moving around until you step on the brakes. Also check the slide pins are installed correctly and the outer pad is snug in the caliper.
Old Jun 3, 2008 | 07:07 PM
oldtimer35's Avatar
Yeah, what he said.
ibra0078
Feb 20, 2015 08:36 AM
91one50
Dec 17, 2008 09:12 PM
riley22
Oct 20, 2008 02:30 PM
dale39
Dec 11, 2005 02:44 PM
cwaire
Dec 16, 2004 08:45 AM
