Sponsored by:
Sponsored by:
Service Bullutin on 87-88 Fords with erratic fuel guage
Old 04-12-2007, 03:07 AM
mkfarnam's Avatar
Default Service Bullutin on 87-88 Fords with erratic fuel guage
1988 Ford Truck F 150 2WD Pickup L6-300 4.9L
Top - Vehicle
Technical Service Bulletins
All Technical Service Bulletins
Fuel Gauge - Erratic Needle Movement
Notes
Article No. 88-18-3
GAUGE - FUEL - ERRATIC NEEDLE (INDICATOR) MOVEMENT
FORD:
1987-88 MUSTANG,TAURUS
LINCOLN-MERCURY: 1987-88 SABLE 1988 LINCOLN TOWN CAR
LIGHT TRUCK:
1987-88 BRONCO, F-SERIES
ISSUE:
An erratic fuel gauge needle when the fuel tank is 1/2 to 1/4 full may be caused by excessive wear of the resistive film on the fuel pump sender assembly. The wear occurs during transporting of the vehicles via rail or truck over long distances. The fuel gauge will indicate correctly from a full tank to about 1/2 or 1/4 tank of fuel. When the fuel gauge needle is below the 1/2 to 1/4 tank range the needle will swing all the way above the full mark on the fuel gauge.
ACTION:
To correct this, install a new fuel pump sender assembly. Refer to the appropriate 1988 Car/Light Truck Shop Manual, Section 24 for detailed service information. Refer to the following fuel pump sender application chart for the correct service part number.
PART NUMBER PART NAME CLASS
E8DZ-9H307-A Fuel Pump Sender AssemblyB
E8DZ-9H307-B Fuel Pump Sender Assembly AM
E8DZ-9H307-C Fuel Pump Sender Assembly AM
E8DZ-9H307-D Fuel Pump Sender AssemblyB
E8DZ-9H307-E Fuel Pump Sender AssemblyC
E8DZ-9H307-F Fuel Pump Sender AssemblyB
E8TZ-9H307-G Fuel Pump Sender AssemblyB
E7ZZ-9275-A Fuel Pump Sender AssemblyB
E9VY-9275-A Fuel Pump Sender AssemblyB
OTHER APPLICABLE ARTICLES: None
WARRANTY STATUS: Eligible Under Major Component Coverage
OPERATION: 881803A
TIME: 1.2 Hrs. - F Series Aft Of Axle Tank
0.9 Hr. - F Series Midship Tank
2.0 Hrs. - F Series Both Tanks
1.2 Hrs. - Bronco 1.4 Hrs. - Lincoln Town Car
0.9 Hr. - Mustang 1.0 Hr. - Taurus/Sable
DLR. CODING: Basic Part No. 9H307
Condition Code: 09
Copyright © 2007 ALLDATA LLC
raymo46
04-29-2012 07:33 PM
barariel
06-05-2011 06:54 AM
mecurtiss
09-01-2009 03:53 PM
TAZ454
12-04-2008 09:03 PM
dawgy
08-01-2006 02:25 AM
Quick Reply: Service Bullutin on 87-88 Fords with erratic fuel guage
