is there such a thing??
I don't remember just exactly what the tube looks like,but this may sound silly , what about a section of flexible stainless dryer vent tubing . Can you try something in that line. I believe different sizes are available and heat resistance shouldn't be a problem. Bonus ,,,,,,,,it's shinny and relatively easy to form. Some are made out of aluminum and that's even easier to work with. What do you think?
I've checked with a few different companies along the lines of 4x4 magazine and even went as far as calling Safari Snorkel in Australia to see if they made one, I've seen them on many samaris and jeeps and a couple fj's and even a land rover. And as for the Aluminum snorkel its a cool thought but that would be alittle too...breakable for my taste I'm lookin for something that will be durable and look decent on the truck I've gotten as far as looking at pvc (2 3/4 i.d.) and getting elbows to make it move to where I want it, and taking a pvc compound that I can bevel the connections as well as make them air or "water tight" and then going to the local scrap yard and getting a fender off of a scrap ford taking my personal one off and replacing it with the trash one and start my cutting and molding that way I'm not cutting into my finder. I've been looking really hard at the 2005-2009 breather box and how its designed for a new breater on my truck to make it air tight and making a sealed box around the ignition coil that has a rubber gasket around the lid as well as making gaskets for my distributor, or getting the boot off of a 93-97 Taurus that went around the distributor so when I sink my truck under water to where I actually have the use for the snorkel I will have everything sealed tight. I know that Safari does sell the snorkel tip separate they really do have an ingenious design to where the water comes out the sides if your driving through the rain or splashing water in the breather from the tires. Sound plausible or am I trying too hard for something that might not work
