04 F350 6.0 fuel pump instrument light on dash
Old 10-05-2007, 09:54 PM
TROY's Avatar
Default 04 F350 6.0 fuel pump instrument light on dash
Help please!
I have the fuel pump with the three little dashes (instrument light)coming on a few minutes after starting my 04 F350 6.0 fwd crew dually. Per local dealership, I have replaced a perfectly good air filter ($77) that didn't help, next after checking/resetting the air intake sensor that wasn't even engaged, i was told to replace it ($25), and then i was told to reset the light by disconnecting batteries for 20minutes. Well, I still have the light lit. The truck runs fine so far. I have browsed through several hundred postings without seeing a fix. I am without owners manual and my haynes manual doesn't address instrument lights.
The other question that my local dealer deisel mechanic could not answer is why my m.p.g. displaystays at 8.5 and has not change in the 7 months I have owned the truck (city,highway,towing or not). [align=right][/align]
Old 10-05-2007, 10:46 PM
Default RE: 04 F350 6.0 fuel pump instrument light on dash
Your refering to the 'Filter Minder' indicator lamp?
Old 10-05-2007, 10:56 PM
TROY's Avatar
yes, i think so
Old 10-05-2007, 11:06 PM
TROY's Avatar
without the owners manual I'm not sure what the sensor light is called but its the same light that comes on with the glow plug light prior to starting the engine
Old 10-05-2007, 11:20 PM
You can download an owners manual here.. https://www.fleet.ford.com/maintenan...ls/default.asp The filter minder (filter sensor) circuit is hard wired to the instrument cluster and the minder provides a grounding connection to complete the circuit illuminating the indicator lamp if the filter becomes resticted.. Could be the cluster itself, or possibly a shorted wire..
Old 10-06-2007, 12:02 AM
TROY's Avatar
thanks for the manual info, im downloading it now. i was really hoping for an easy fix with the sensor light but don't it look like it will be too simple. still looking for fix for M.P.G. display stuck on 8.5 average mpg's.
Old 10-06-2007, 05:18 AM
Ask around FTW here
http://fordtruckworld.tenmagazines.c...p;n=super_duty
Or here at GoGoDiesel . The people on here know their diesels......
http://www.gogodiesel.com/forum/index.php
Old 10-06-2007, 09:56 PM
leo1's Avatar
the dash light is telling you you have water in your fuel filter. come on guys read your owner's manual, don't just look at it and say you read it
Old 10-21-2007, 09:19 AM
Have you tried resetting your mileage indicator by holding down BOTH bottons at the same time on your over head console? If not then 8.5 is what you have averaged over the life of your vehicle.
jozepy24
07-13-2019 05:21 AM
fordexpedition2006
04-21-2017 05:23 PM
Spaznaut
05-24-2014 02:10 PM
easyriddin48
12-18-2010 02:42 PM
TROY
10-06-2007 07:43 PM
Quick Reply: 04 F350 6.0 fuel pump instrument light on dash
