1999 F-250 will not start
Old 03-13-2007, 05:53 PM
Morris72's Avatar
Default 1999 F-250 will not start
I have a 1999 F-250 4x4 5.4L engine130000 miles. Truck started as normal drove for about 3 to 4 miles and died, cranks but would not start, 5, 10 minutes later refired and drove back home. Truck restarted several times and seemed to run fine, did have high idle, and has had for a few days. checked and cleanedthe normals, MAF, Throttle body, etc.
Have power to all gauges, no service engine light, butcan not hear the fuel pump run. I am leaning towards 50/50 betweenfuel pump, and PCM.
Would like to here any suggestions or ideas, or if anyone else has ran into this problem.
Thank you for your response
Morris72
Old 03-14-2007, 12:43 AM
goinstrong's Avatar
Default RE: 1999 F-250 will not start
First look in your owners manual for a fuel pump reset switch (I hope to god the company isn't so stupid as to have put them on trucks). If you're good with not having that (as I assume) then look for a bad fuse or fusible link to the pump or ignition. You also would do good to crank it over and check for fuel pump pressure (provided you have a pressure tester or the accessory know-how).
robin savell lloyd
05-23-2016 03:58 PM
delong.kyle@yahoo.com
11-17-2012 02:10 AM
99Escort20
06-10-2008 09:35 PM
flatheadfooser
08-12-2007 11:57 AM
brobichaud
07-20-2007 02:43 PM
Quick Reply: 1999 F-250 will not start
