2000 F350 V10 Gas dually not going into 4WD
Old 04-04-2013, 06:12 PM
v10scarab's Avatar
Default 2000 F350 V10 Gas dually not going into 4WD
Was stuck in the mud the other day with a boat behind me. 4x4 light comes on and it appears to engage when running but not from a stop. Hub appear to engage but front wheels aren't engaging. Any ideas?
Old 04-05-2013, 01:39 AM
Do you have a copy of the owner's manual, it should explain that when the hubs are in auto position, the vehicle has to be moving over 5 mph.
If the vehicle can't get any traction to go 5mph you may need to lock the hubs manually.
Old 04-16-2013, 08:49 PM
TuRBoWHiNe's Avatar
you could also have cracked vacuum lines that run to the hubs...
codyaf
11-22-2010 02:56 PM
coondog
10-06-2010 07:32 AM
bosanci28
04-17-2010 11:33 PM
rustbucket89
11-08-2009 09:05 PM
2excowner
12-05-2005 06:26 PM
Quick Reply: 2000 F350 V10 Gas dually not going into 4WD
