Door Panel Pain
Old Oct 5, 2007 | 04:09 PM
johndeere88's Avatar
Default Door Panel Pain
Hi, i recently bought a 2001 f-350 XL and im trying to put in aftermarket powerdoor locks but i'm having trouble pulling off the door panels, someone have tips for me?
thanks
Old Oct 5, 2007 | 04:54 PM
Default RE: Door Panel Pain
Pull the armrest trim panel pad off at the 'front' of the armrest.. Just the nose piece.. There will be a screw inside.. Then pull the lower door reflector out by inserting a screw driver in the opening and 'gently' moving the release tab as you pull lightly outward.. There is a screw in there as well.. Remove therear view mirror 'inside' trim cover (black) at the front/upper most of the door/panel by pullling it straight out/off.. Remove the window crank by snapping the cover off the big end and swing away to access the torx screw inside.. Then 'lift' the panel from the door shell, don't pull outward until the trim panel legs clear the shell.....
Old Oct 5, 2007 | 05:02 PM
thanks a bunch ill try it tonight!
Old Apr 21, 2009 | 10:07 PM
Thomas Fritzky's Avatar
hi guys, I have a winstar 2001 with a similar problem. I am going to try the same method on the van's panel. It's the same year so It might work.
What do you think?
fritz
Old Apr 21, 2009 | 11:19 PM
Hi Fritz.. Welcome to the site..
Similar, but some differences..
Remove the window regulator master control switch panel. Snaps down to the trim panel.. Unclip the harness connectors..
Then the door handle escutcheon by carefully prying it away from the panel.
Remove the upper mirror access cover. Snaps to the door/frame shell..
Remove the 4 front door trim panel screws. 2 at the bottom, 2 near the handle/arm rest pull and 1 behind the mirror trim panel
Lift the panel off of the locating legs..
makuloco2000
Dec 13, 2014 08:41 AM
evatt
Jul 12, 2009 11:06 AM
Drunkship
Apr 19, 2007 04:33 PM
chaud
Jul 22, 2006 01:55 AM
steveandbelinda
Jun 19, 2006 01:30 PM
