Fuel Injector low voltage
Old 01-16-2009, 09:16 AM
homie241's Avatar
Default Fuel Injector low voltage
I have a 2004 F-250 with the famous 6.0 power stroke. The truck has 80,000 miles on it and I have not had a problem until now. I am getting codes for all cylinders having a low voltage for all fuel injectors. Any ideas? Could it be a bad contoller or could it be a weak batteries set up? I have two ultima batteries installed. Any feedback would greatly appericated it. Have a good day.
Old 01-17-2009, 12:07 AM
marks460's Avatar
Default RE: Fuel Injector low voltage
hi, not a big fan of the 6.0l engine -but have worked on a few and with your concern the repair always called for a new idm/ecm modulei would get a diagnostic tool tests run buy someone who really knows the 6.0l though because it is an exspensive repair.
Old 01-17-2009, 02:24 AM
Well within the warranty limits as well...
Old 02-10-2009, 06:13 PM
homie241's Avatar
Smile Ficm
Thanks to all that helped. The FICM (Fuel Injection Control Module) was bad. Ordered rebuilt one and turned into Ford to reprogram. It is covered under warranty. My truck was out of warranty and it ran 250 for labor and 700 for parts. All in all it was not a bad fix. If anyone out there runs into this and orders one on line just a word of advice. The FICM does not come pre programmed. Leave old one installed and turn into Ford to have old FICM downloaded and reloaded onto new FICM. Thanks again.
joachim1340
07-11-2012 09:29 AM
ojulin63
04-25-2009 11:08 AM
stevenjames
02-10-2009 07:58 PM
celesteholt
09-12-2008 01:02 AM
stevenjames
08-17-2007 01:37 PM
Quick Reply: Fuel Injector low voltage
