low voltage
Old Sep 8, 2008 | 08:22 PM
celesteholt's Avatar
Default low voltage
just bought a 1993 tbird, has new battery, has new alternator. was driving home and blinkers quit. then the air conditioning quit. then the voltage gauge started to dip near the 8. turned it off. wouldnt restart. jumped it, ran fine- with blinkers- then 20 minutes on my way, the air and blinkers quit again. just checked all the fuses and they look fine. what now? also, lighter and rear defrost dont work.. but all the fuses are fine...
Old Sep 12, 2008 | 01:02 AM
goinstrong's Avatar
Default RE: low voltage
Sounds like a bad fusible link, a dual filament bulb with a blown and crossed filament or some wires that fried together. Start with the easiest and check the fusible links, then any brake and turn combination bulbs, then last try disconnecting the battery and tracing the wires from problem sources like lighter and rear defrost,etc.
carelectronicsjosh
May 23, 2009 12:30 AM
ojulin63
Apr 25, 2009 11:08 AM
stevenjames
Feb 10, 2009 07:58 PM
homie241
Feb 10, 2009 06:13 PM
stevenjames
Aug 17, 2007 01:37 PM
