Loss of power while driving
Old 04-04-2017, 08:57 AM
David Gonzales's Avatar
Default Loss of power while driving
Hello, my f250 with a 7.3 is losing power after I reach 60 mph, then it drops dramatically in power will only go 25-20 mph and almost stalls. I had 3 codes p1280,p1670, p0470 and truck barely idled. I replaced icp sensor, uvc harness and valve cover gasket. I'm taking off ebp sensor and tube today and cleaning and inspecting for clogs or leaks in tube. Had live diagnostics ran on it also, everything showed good. Definitely can use help at this point. Trying to keep her out the mechanic shop.
Old 04-05-2017, 11:40 AM
eric hoffmeyer's Avatar
Sounds like a fuel starvation issue as a possible cause.
Remove the fuel tank cap and try it again. If it still looses power see about a clogged fuel filter.
Eric
Old 07-25-2017, 04:59 AM
ya might want too check out the filters inside the sending unit 2 in number they look like 410 shells lol dove me nuts fer sure joseph
Old 07-25-2017, 11:15 AM
1280 and 1670 doesnt follow a fuel depleation situation although exhaust pressure possibly', and generally if a low flow/pressure wont affect idle conditions. A severe enough fuel delivery issue that would affect idle, doubt the truck could make freeway speeds. When the screens restrict it usually will result in a 'flat throttle' most times mid range and higher and will quickly straighten out when some or all of the throttle angle is removed. Most noted at highway speeds or pulling steep/longer grades as the demand for fuel increases. A pressure tester installed and monitored during an event will prove out fuel delivery concerns. The micro filters are a common fail, but a simple pressure test may be of benefit before a tank drop.
ICP, PCM/IDM and EBP
Replaced ICP,, were any of the connectors unplugged for testing/ checks for leaking etc with ignition ON? Or are theses now retest codes? Codes should be addressed in the order they were stored, (if you listed them as reported) but it could be a harness/connector issue so some inspection there w/without DVOM, wiggle test etc. Or could be components themselves. What were the IPR/IPC values at idle when running rough?. Improve with a IPC disconnect? PCM/IDM dropout or intermittent could certainly cause misfire, idle, and running concerns.
Not sure how the live data would be all good if IPC is off, comm between the PCM/IDM is in question, and EBP is off spec..
Old 07-29-2017, 06:26 AM
check your retu9rn fuel line it may be jammed up..
Fordmanxlt 31
06-01-2011 09:58 PM
tobeintheshade
09-14-2010 05:18 PM
Fireball69
03-25-2006 03:41 PM
Kim
03-09-2006 07:12 PM
txdiesel
10-11-2005 07:43 PM
Quick Reply: Loss of power while driving
