rear coil spring
Old 12-24-2016, 12:42 PM
jimboe's Avatar
Default rear coil spring
Hi All, I need both rear coil springs on a 2005 ford 500 awd.
I was told that they are discontinued. There has to be another coil spring that could work. Does anybody know how I would go about getting the measurements and info needed on these springs?
This would be really rotten if they don't make the spring for this car.
Mechanic said it is causing rear tire wear. He said he tried to find them but to no avail.
Old 12-24-2016, 01:49 PM
Not sure if it has struts back there or just coil springs.
Complete strut assys may be easier to locate.
Old 12-24-2016, 02:56 PM
jimboe's Avatar
Hi hanky,
The mechanic said that just replacing the struts won't do anything. The rear end is sagging which is causing "excessive wear" on a part for the alignment.
He said to me to just try rotating the rear tires for even wear. I read were other people with other cars like,Montego,Freestyle and some others are having the same problem finding springs. Someone suggested to get the info of the springs and have them made.
I would think that even another spring from another car or even a truck may work.
Ok I see, you mean the whole assy. Yes I will have to check on that. Thanks
nickf15091
03-14-2012 11:32 PM
ljcorby
05-05-2009 11:15 AM
thecustomshop
09-30-2008 01:44 PM
spinbad
12-22-2006 12:32 AM
billj818
11-18-2006 09:27 PM
Quick Reply: rear coil spring
