04 freestar water pump repair
Old 08-30-2011, 01:12 PM
ralfs04freestar's Avatar
Default 04 freestar water pump repair
Does anybody know if the motor has to be dropped to replace the water pump ?
Old 08-31-2011, 07:31 AM
Use Common Sense's Avatar
You should be able to replace the water pump with the engine in the vehicle. You'll just have to remove items to gain full access. If you've never done a FWD water pump, I would recommned taking pictures before and during the dis-assembly to help re-installing everything in their proper place.
Old 10-21-2014, 08:32 PM
Bracsim's Avatar
negative, you just need to lift the engine about 2 inches, loosen the engine mounts, lift the engine under the oil pan and you will be able to replace the water pump, I did it in my 2004 and that's the only way to do it.
Old 10-27-2014, 06:53 AM
John Renold's Avatar
Hi friends! How do I change a water pump on my ford freestar van? Can anyone guide me?
Thanks in advance
Old 01-06-2015, 03:37 AM
jmil67's Avatar
Angry ford freestar
just replaced my w.p p.i.t.a but now wont crank at all,any help would be appreciated
Use Common Sense
07-02-2015 12:16 AM
makuloco2000
10-03-2014 02:42 PM
mattsauto
10-20-2010 02:30 PM
sheebeehuh
01-14-2006 01:01 PM
Quick Reply: 04 freestar water pump repair
