Dangerous ever fault.
Hello every one.
My Ford Freestar have one problem, when I Take fuel from gas station, it throws out the oil as the air inside could not goes out properly, one/two liter fuel also gets wasted due to this....I was ignoring this problem,
few days ago, my car suddenly got off on the road, i was on 30 KM/h speed, it jammed the breaks as will as steering wheel, which means...i can't turn my car and can't stop it....ohhh!!! what a biggest fault ever noticed in automatic car.....you can't turn your car and can't stop it if its suddenly off while running????
please let me know what to do ...should i check my fuel tank valve?
thanks in advance.
thanks in advance.
There are two valves usually operated by solenoids that sometimes stick in the wrong position or don't function as required. They are part of the fuel evaporation system to control vapors from going into the air. It sounds like one of them is stuck in the wrong position. It would be best if you had a good shop check them.
andrew123
01-03-2007 12:02 AM
JoeBlowRacing
08-09-2005 05:50 AM
