Melted intake manifold - Stuck EGR valve?
Old 05-20-2009, 10:46 PM
jdmchugh's Avatar
Default Melted intake manifold - Stuck EGR valve?
I own a 2004 12 valve Taurus (SOHC).
I recently had a code come up saying that I had a vacuum problem (P2197).
I ignored it, figuring that I would get to it later.
I finally brought it in to my mechanic when it developed a rough idle and really poor acceleration.
They checked it and determined that the problem was actually a defective coil pack.
Over the week that followed the replacement - the performance became worse and worse until the car could no longer go faster than 10 MPH and would not sustain an idle.
When the mechanic checked it - they found that there were a number of holes melted through the intake manifold.
I decided to replace the manifold myself today - and it is already starting to show the same problems (poor/rough idle - poor excelleration). And, it is trying to develop the same melt holes. It is now showing codes P0171 and P2197. I believe those correspond to 'lean bank 1' and vacuum fault.
The best that I can figure is that the EGR valve is somehow stuck open and super heated exhaust gases are feeding back into the manifold - melting it. And a the excessive exhaust feedback is causing the car to register a vacuum failure.
Has anyone else heard of anything similar to this? Is the EGR line supposed to get so hot that it glows red (in the dark)?
Old 02-22-2015, 05:59 PM
07ford500's Avatar
i have the same issue please help! what causes this to happen???
Old 02-23-2015, 05:38 AM
jdmchugh's Avatar
Default Here is what mine turned out to be
I no longer have that car, but I did figure out what was causing it for me. And, that was a clogged catalytic converter.
It was forcing the exhaust back through the engine.
Hope that helps.
fordborn
06-10-2013 10:19 PM
outlander330
04-01-2012 10:07 PM
daveranger
05-26-2008 07:08 PM
lesj
08-23-2007 12:07 PM
sgtmark2
01-30-2006 02:08 PM
Quick Reply: Melted intake manifold - Stuck EGR valve?
