2013 oil level
Old Feb 4, 2015 | 03:46 PM
mrpike's Avatar
Default 2013 oil level
I still do my own oil changes and when I refill the crankcase with the prescribed 6 quarts it reads high on the dipstick . is this normal ?
Old Feb 4, 2015 | 06:10 PM
If the filter was changed some of the oil over the full mark will go to fill the oil filter.
What does it read after you run it a minute then shut it down ?
Old Feb 7, 2015 | 11:54 AM
mrpike's Avatar
IT seems to read about a half a quart over the full mark
Old Feb 7, 2015 | 01:48 PM
With the filter mounted at an angle some of it still drains out into the crankcase. With the engine running that 1/2 qt goes back into the filter and the level is right where it should be.
Old Mar 9, 2015 | 02:21 PM
JackC's Avatar
It is more likely the car was not level. Being on a very slight grade can cause the dip stick reading to read slightly high or low.
You have a 2013 so it may not be your issue but as the engine mounts wear the engine can slightly sit out of plumb level. I have noticed this on my 19 year old car.
Turn the car around. Park it in the same exact location and check it after sitting for 10 minutes or longer.
renatosc123
Sep 15, 2013 04:08 AM
trev0006
Jun 6, 2012 01:20 PM
Sutol
Mar 26, 2009 03:36 PM
ddareaustralia
Dec 27, 2008 04:12 AM
