Ford Tempo/Probe These small cars offered a sporty feel and affordable price.
CLutch gone ! grr
Old 01-28-2008, 09:34 PM
fordprobation1's Avatar
Default CLutch gone ! grr
My clutch pedal goes all the way to the floor.
I can't get my car in gear , unless I really ram into gear.
I just parked the car.. I am assuming that this might be
the clutch hydrolics cylinder...? The seals may have gone bad ? I am hoping so, this would be a really economical fix.
Can someone lead me to a good diagram of the clutch cylinder and where it's located. The book I have has a
terrible diagram. Thanks !
Old 05-12-2008, 02:09 AM
goinstrong's Avatar
Default RE: CLutch gone ! grr
If the pedal dropped all of a sudden it could be the cluth master cylinder or if it slowly wore down over timeand you DON'T have a brand new clutch then the clutch could be gone (they don't last forever). Basically if you cranked 50 grand on the car, raced it around some - the clutch could be gone. The hydraulic master cylinders usually have a bleeder screw to bring the pedal up (if you changed out the transmission clutch recently). It's either located on the clutch master cylinder (near/around the reservoir) or at/around the slave cylinder. A small mirror may help in locating it if it is on the trans. .
makuloco2000
07-22-2014 08:33 PM
jmelees
05-17-2012 02:38 PM
cyberrkatz
07-07-2010 09:46 PM
skid2964
09-27-2009 02:29 PM
mmmahlstede
08-29-2005 01:12 AM
Quick Reply: CLutch gone ! grr
