Clutch Problem... pedal drops to floor, clutch stays engaged.
Old Sep 21, 2009 | 09:06 AM
skid2964's Avatar
Default Clutch Problem... pedal drops to floor, clutch stays engaged.
I had this happen once before, I replaced the clutch master cylinder and all was well again.
Now it's doing it again, the pedal will drop and the clutch is engaged, but this time I pull the pedal back up with my foot and everything is ok again.
It was low on fluid, I refilled it, will air in the system cause it to act like this?
-1995 F150, 6cyl, 2WD
Old Sep 22, 2009 | 08:42 AM
Bullitt94's Avatar
Air could cause problems. Try bleeding the line.
Old Sep 25, 2009 | 05:17 PM
skid2964's Avatar
It was the clutch master, replaced it but now I cannot bleed the system.
The fitting that is supposed to loosen so I can bleed will not come loose. If I twist on it any harder it will twist off the tube.
Will these system sort "bleed themselves" if I dont bleed it?
The pedal is very mushy, but it works.
Old Sep 27, 2009 | 02:29 PM
Bullitt94's Avatar
You should bleed it. Try some PB Blaster on the stubborn fitting.
spatterfree
May 5, 2014 08:45 AM
deano1960falcon
Dec 17, 2008 12:37 AM
WindstarWorkHorse
Dec 21, 2007 07:56 PM
daveranger
Jun 27, 2007 08:00 PM
cope607
Mar 13, 2006 03:56 PM
