f150 f250 engine swap tech guys need your help
Old 10-02-2006, 12:10 AM
redracing88's Avatar
Default f150 f250 engine swap tech guys need your help
i got a f150 night with a 302 fuel injected engine. the motor is bad beacuse it smokes highly. well i got a 351 out of a f250 the years of the f150 a 91 and the 250 is a like 92 so there bout the same year. i though maybe i if i swithced the computers they would work well the comuters numbers almost line up there like a couple numbers off but like on the 150 most the numbers are one and on the 250 its alot of 2 but otherwise they seem to match and the computers bolt right up. otherwise all engine components are the same. will this work or not?
Old 10-02-2006, 08:52 AM
Default RE: f150 f250 engine swap tech guys need your help
If the wiring harness seem's to be the same i would use the computer for that engine.[hr]If it does not run or run right you will have to change the harness.
Weekend Wrench
04-01-2014 08:41 PM
Bassquack
07-14-2013 01:45 PM
redracing88
10-02-2006 12:07 AM
Quick Reply: f150 f250 engine swap tech guys need your help
