Old Gal won't start.
Old 12-18-2014, 07:01 PM
Dadeputy's Avatar
Default Old Gal won't start.
Greetings,
I have a 65 Ford Galaxie with a 352. About a month ago, it began missing and stalling when placed in drive. It also did the same when idling. I checked to see if the gas was the problem and added some HEET to dry up any water. Didn't help. The starter solenoid melted, so I replaced it. Still nothing. I tried starter fluid and that didn't work. In the middle of replacing the coil with a Pertronix Flamethrower and the points with a Pertronix 1281 electric ignition module. I'm hoping this will do the trick. Any suggestions if these do not remedy the situation?
Old 12-19-2014, 07:40 AM
On those engines vacuum was an important function. Did you check for any vacuum leaks?
Old 12-19-2014, 06:58 PM
Dadeputy's Avatar
No not yet. Any suggestion as to where to look first.
Old 12-20-2014, 05:43 AM
Start at the top of the intake manifold and look for any cracked or broken hoses. If the hoses are in fairly decent shape you can pinch them with a pair of pliers to eliminate each one. If the vehicle has vacuum powered brakes that would be a larger hose coming off the intake manifold.
Old 12-22-2014, 03:28 AM
Dadeputy's Avatar
Thanks for the info. The original air cleaner has been replaced with an aftermarket chrome Edelbrock version. Off the brake booster there is a hose that goes to a module on the transmission. I'll take a look at all the hoses today and let you know what the results are. Thanks again for your time.
Mo Junk
07-13-2020 03:49 AM
Foxy_72
07-21-2015 02:59 AM
edc
10-06-2007 06:05 PM
waitn4ford
11-27-2005 07:52 PM
wagonslayer
07-09-2005 04:10 PM
Quick Reply: Old Gal won't start.
