ford contour 96 brake lights won't work
Old 04-06-2009, 05:02 PM
svargas0304's Avatar
Default ford contour 96 brake lights won't work
my brake tail lights are out on my contour but the one in the window works but the tail lights don't check fuses ok bulbs ok but still not working anyone knows whats wrong
Old 04-06-2009, 05:25 PM
Welcome to the site..
The high mount/3rd brake lamp is a 'direct feed' from the brake pedal/stop switch to the high mount.. The Stops/Turns run through the multi fiunction switch (turn lever switch).. If selected, do the Hazards flash the tail lamps?
Old 04-08-2009, 04:53 PM
thanks for the respond found out it was the turn signal switch
svargas0304
12-30-2010 04:24 PM
nharvey29
08-16-2008 10:25 AM
puddinnut
01-22-2008 07:06 PM
Quick Reply: ford contour 96 brake lights won't work
