1998 ford expe brake lights do not work!
Old Jan 19, 2008 | 11:09 PM
puddinnut's Avatar
Default 1998 ford expe brake lights do not work!
My brake lights aren't working. , But only 1 light workson top of the hatch. and turn signals and parking lights work fine. The brake lights don't work. I changed the fuses changed the bulbs and they are fine. Does any one has some suggestions on why they wouldnt work?!!!
Old Jan 20, 2008 | 05:06 PM
btexpress's Avatar
Default RE: 1998 ford expe brake lights do not work!
After what you have already done, I would go after the switch, unless you have already determined there is voltage to the bulbs.
Old Jan 20, 2008 | 09:02 PM
puddinnut's Avatar
the tailights n turn signals work but when i push on the brakes the only light that works is the 3rd 1 on the hatch. Could that be the the switch and if so what n where is it?!
Old Jan 20, 2008 | 09:23 PM
btexpress's Avatar
If the high stop light works, then most likely the problem is in the multifunction switch on the steering column. All stop lights get power thru the stop light switch, so if the high lamp works then you know the stop lamp switch is ok.
If you notice any problems with the interval wipers or windshield washers, these functions are also part of the multifunction switch.
Old Jan 22, 2008 | 02:36 PM
puddinnut's Avatar
first i just want to tell you i appreciate all your help! i change the switch thats located underneath the brake petal. and the lights still do not work. is that the switch you were talking about?
Old Jan 22, 2008 | 02:46 PM
btexpress's Avatar
ORIGINAL: puddinnut
NO, the switch I mentioned is on the steering column
Old Jan 22, 2008 | 03:30 PM
puddinnut's Avatar
im not sure where that switch is. im sorry kinda clueless when it comes to these things. could you explain in detail please?
Old Jan 22, 2008 | 03:55 PM
btexpress's Avatar
You can locate the turn signal and wiper controls? These are part of the switch I referrred to. Remove the upper steering column trim and you can access the mounting screws
Old Jan 22, 2008 | 07:06 PM
puddinnut's Avatar
and how do i check it?
stevprin
Jul 15, 2019 08:33 AM
Jeff Salamy
Jan 22, 2015 03:22 AM
chadl73
Sep 28, 2012 09:05 AM
marty
Dec 5, 2007 12:23 PM
marty
Dec 5, 2007 12:22 PM
