Check engine light confusion? Please help.
Old 08-23-2015, 03:24 PM
Elijah Bramer's Avatar
Exclamation Check engine light confusion? Please help.
So i had a engine light on and so it was for an O2 sensor, or so i thought. I went and replaced it, but now i have eight pending faults on my ECU. here they are and please share any comments on what the problem may be..
P1504
P0136
P0401
P1131
p1151
p0301
p0302
p0303
Oh and its a 2001 Windstar LX
Thanks again
Old 08-23-2015, 05:21 PM
primem's Avatar
these are all pending dtc that have set after you cleared the dtc after the 02 replacement?
when misfire dtc p0301 run and set; the 02 monitor p0136 won't even run...so I doubt these are pending codes. usually what I would recommend is to clear all dtc and see what returns.
Old 08-23-2015, 09:27 PM
Okay so i have done that and now only 0301,0302,0303,0401, and 1504 is left still. and i also found out that i have some arc coming from my spark plug wires wherever they are touching outher spark plug wires or a piece of grounded metal.
Old 08-23-2015, 11:15 PM
primem's Avatar
that explains the misfire dtc. so replace the wires, route them correctly and clear all the dtc and see what returns.
Old 08-23-2015, 11:38 PM
Okay, will do that and update. Thanks alot
Old 09-06-2015, 12:05 PM
Update, replaced the plugs and wires, now it only has code p0401 but I had already replaced the rectangular dpfe sensor on the rear of the engine. Any idea?
Old 09-09-2015, 08:32 PM
primem's Avatar
can you confirm the egr valve is opening?
Jace
02-22-2013 06:59 AM
scottparker
12-31-2012 02:06 PM
juangoodude
11-27-2008 09:21 PM
OK_66
07-23-2008 08:16 PM
Sygerwulf
06-27-2006 03:33 PM
Quick Reply: Check engine light confusion? Please help.
