Appearance Talk about your interior and exterior mods here.
Add Door Lights to XLT
Old Jul 9, 2024 | 11:41 AM
Melvinluis's Avatar
Default Add Door Lights to XLT
Looking to add Ford door lights to my XLT, fairly sure they are 8 pin (power, heat, blinker, driver side auto dim, no fold or BLIS)
Is there somewhere to tap into in the door modules and then re program with forscan to achieve this, or will running new wiring be the easiest?
Old Jul 9, 2024 | 12:04 PM
Do you mean the one like footwell light but locate on the door pointing toward the door jamb and the ground when you open the door? If that's the case do you want to control that just like your dome light? Do you also need a switch to control ON-OFF?
Please check my signature since nobody has a clue on that info.
I can get you the electrical diagram as well as how to wire it up if your vehicle is 2009 or older.
365 Bullitt
Jun 18, 2021 01:31 PM
wolfwithinme29
Jan 20, 2010 02:21 PM
pats99ranger
Feb 17, 2009 12:25 PM
robinas4
Dec 19, 2008 11:10 AM
66GT
Apr 3, 2007 10:40 AM
