1968 Torino GT
Old Dec 5, 2006 | 10:05 PM
pollok22's Avatar
Default 1968 Torino GT
I have a 68 torino with a 302, and lately my car has been dying when I'm in lower RPMs,stoppped at a light, or coming to a stop. I've also started my car, and while sitting in park, turned on my lights and my car has died. It dies more often when I have other things going like lights, radio, windsheild wipers. When it first started doing it, my car would just start right back up, but then it started to die and I wouldn't have any power for like 3 minutes, no lights, horn, etc...nothing. Then I figured out when it died and I had no power, that I could press the horn button rapidly and I would regain power, and I could start my car. I have a new battery, and I have had my fairly new alternator tested on and off the car. On the car it doesn't put out as many amps as it should, around 50-55 and its a 60 or 65 amp alternator, but off the car, the machine says its good. On one hand it sounds like not enough volts at low RPMs, but then I have the problem with totally losing power for 3-5 minutes. I also have a MSD ignition box, possibly a problem there. Maybe a problem with my coil. If anyone has an idea, please let me know. Thanks!
Old Dec 31, 2006 | 03:42 AM
DJames's Avatar
Default RE: 1968 Torino GT
Sounds like a negative battery cable issue of some sort. Try cleaning up both ends of it and see if that helps.
Old Apr 8, 2007 | 10:57 PM
goinstrong's Avatar
The regulator controls electrical output. It's very likely it could be going bad.
pollok22
Dec 6, 2006 11:14 PM
XFILE
Sep 10, 2006 07:56 PM
rebelman108
Jun 27, 2006 12:11 AM
victoria
May 17, 2006 12:20 AM
Fastronald
Jan 15, 2006 07:41 PM
