67 Galaxie Solenoid Problem
Old May 26, 2018 | 10:02 AM
fatdirt's Avatar
Default 67 Galaxie Solenoid Problem
I was under the hood checking a couple things when I ask my wife to start it. A shower of sparks flew out of the solenoid. I bought an Accel replacement. I removed the old one with the wires still attached. Then I mounted the new one and moved the wires one by one to be sure they all went back the same way. However, now the starter kicks in and you can here the motor catch and fire but as soon as you release the key, the motor stops. It turns off just like you had turned it off with the key. Any ideas? Thanks!
Old May 29, 2018 | 02:22 PM
Sanddoc's Avatar
once your engine starts\runs, the solenoid is not in the circuit any longer.
I'd say you have a lose or broken run wire..
check the coil connection Turn the engine to run and see if you get 12 v
Not start, run
Old Jun 7, 2018 | 08:42 AM
fatdirt's Avatar
There seems to be an intermittent short in the new solenoid. I put the old one back on and the car runs fine.
Old Jun 8, 2018 | 07:08 AM
Sanddoc's Avatar
that's great.
best
fastonraceday
Nov 7, 2019 07:46 PM
bluewind
Jul 18, 2016 07:22 AM
chevySlayer
Nov 7, 2015 03:09 PM
willebgone
Oct 3, 2012 04:43 PM
brentbone55
Nov 24, 2011 10:38 AM
