Heater box
Old Jun 15, 2018 | 10:38 AM
Sanddoc's Avatar
Default Heater box
One day
Anyone who has a 62 Galaxie or the associated wagon and
has removed the Heater box, is there something I'm missing..
The manual says to remove the retaining nuts.. I see no retaining nuts
the heater box sits on the sound insulation as far as i can tell..
I know I need to remove the hoses. But I'm talking about taking the
heater box out... What did you do!!!!
Just so we don't have a miscommunication. this is up under the dash
under the glove box and radio...
Best
Dave
Old Jun 15, 2018 | 01:54 PM
Sanddoc's Avatar
Default heater
OK, so I should have "thought" and looked at the firewall..
the heater box has studs that push through the firewall and
speed nuts are used on the engine side..
So now you know the rest of the story!!!!
Best
Old Jun 15, 2018 | 03:31 PM
Thumbs up
Most are that way,, although they like to sneak a hex sheet metal on occasion from the interior. More so GM.. Or hide one behind the inner fender ...
Old Jun 16, 2018 | 07:07 AM
Sanddoc's Avatar
I'm just glad I "thought" to look...
I just need to move it so I can put in the new floor pan... and of course while it's
out, I'll do a little cleaning, de rusting of a few parts I see... maybe some fresh paint..
Best
Old Jun 17, 2018 | 03:17 PM
Sanddoc's Avatar
update..
The clove box needs to come out...
there are 3 cables One on the front, One on Top and one on the backside...
also there is a large oval airduct on the Top right (when facing forward)
just wanted to mention that... pluse the two air ducts...
Best
Old Jun 20, 2018 | 08:40 AM
Sanddoc's Avatar
just another up date on the heater box.. Guess I'm doing this so the next guy
has some insight..
The heat box is I think fiberglass, with a tin sheet plate on the side facing the
firewall.. It is held in place by bent over metal tabs...
The heater core is not really "held" in place, but there are 4 plastic nubs
protruding and are held by a type of (c clamp) remove this clamp and turn the
nub quarter turn.. there is a slot for a striaght screw driver.
then just pull up on the heater core..
Like always take care when bending those metal tabs when removing the metal
plate.. it needs that even pressure all around the box...
Best
paulv718
Jan 18, 2017 09:23 PM
1fastp71
Jan 27, 2007 02:25 AM
1fastp71
Nov 29, 2006 07:14 PM
VicOnVogues
Oct 19, 2006 10:00 PM
brownr
Feb 28, 2005 06:59 PM
