Strut support
HI all
has anyone installed a pair of gas struts to support the hood of your Galaxie? mine is a 62 if you have please pass on Info Best Dave |
Didn't Ford use heavy springs to support the hood or was it a prop rod?
they are spring. I've run into an issue where the the passenger side of the hood will not close.. this is not a spring problem.
and I don't understand how it occurred I've taken the hinge off the car, tighten it up... and still the hood is at least 1" up... I've made all the adjustments I can... thanks for your input Best |
