Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
rear power window issue 95 eddie bauer 5.8l
Old 06-24-2017, 09:59 AM
dworth24's Avatar
Default rear power window issue 95 eddie bauer 5.8l
im not having issues with the motor per se but the key cylinder to lower and raise the window is giving me a problem. i got inside the tailgate and see a small box (tailgate key switch) with 2 buttons on it. one button loweres and one button raises the window. when i push the buttons manually the window goes up n down. but using the key from outside, i can make window go up but it wont go down even though it seems the paddle on the key cylinder hits the button, just not hard enough i guess. have you dealt with this issue. wondering if the key cylinder has too much play in it. any resolution ideas ????? thanks
Old 06-10-2018, 05:44 PM
Steve83's Avatar
Add a spacer to the DOWN side of the paddle so it presses the button more.
For more info about the tailgate, read the captions in this photo album:
https://www.supermotors.net/registry/2742/12689-4
babygirl9272
09-06-2019 09:38 PM
kaeden1100
05-20-2017 02:05 PM
samanthalornn
06-09-2014 04:52 AM
unclejosh
05-01-2011 09:17 PM
hilliad
09-08-2008 12:08 PM
Quick Reply: rear power window issue 95 eddie bauer 5.8l
