Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
93 bronco sluggish on take off
Old Jan 18, 2009 | 01:15 PM
autosskid's Avatar
Default 93 bronco sluggish on take off
my 93 bronco is sluggish on take off. it has the 5.8 and theAOD trans. it had no light on in the dash and no codes in the comp. the fuel psi is good. im out of good ideas any suggestions?
Old Jan 18, 2009 | 09:48 PM
Bullitt94's Avatar
Default RE: 93 bronco sluggish on take off
Have you tried anything along the lines of a tune-up or anything else? If so, what have you tried so far?
Old Jan 18, 2009 | 10:07 PM
autosskid's Avatar
Yes I have put plugs, wires, cap, and roter button, air filter fuel filer,... I installed a new ecm I have tryed an exturnal fuel pump in a bucket of fuel
Old Jan 18, 2009 | 10:12 PM
autosskid's Avatar
And I have also checked for vacume leaks.
autosskid's Avatar
Old Jan 19, 2009 | 08:53 AM
Bullitt94's Avatar
Is the air cleaner filter in good shape? Are all of the plugs firing? Is the engine running fine at idle and while driving/accelerating?
Old Jan 19, 2009 | 09:10 AM
autosskid's Avatar
yes the air filter is good and clean and all the plugs are firing, the motor starts and runs great and once you get up to speed it seemes to do ok the idal is smoth and it never seems to miss, when you asselrate it bogs down speed incresses but very slow if you just ease on the throtal it will gain speed much quicker
Old Jan 19, 2009 | 06:39 PM
fblevins1's Avatar
So you are saying that when you tried the external Fuel Pump and a bucket of fuel that did not help the problem and that the problem still existed?
Because that sounds like either a fuel pump getting ready to go bad, or partial blockage in your exaust or Cat converter.
Old Jan 19, 2009 | 09:21 PM
Bullitt94's Avatar
I was starting to lean toeard the blocked catalytic converter or exhaust as well. Have you noticed the catalytic converter getting excessively hot or even red hot?
Old Jan 19, 2009 | 10:18 PM
autosskid's Avatar
I have been asked about the cats and a previous owner has had them cut out and they have installed true dules with single chamber flowmasters needless to say the pipes are cleen I droped the pipes about a month ago to install a new trans and didn't notice any loose parts in the pipe... The pump I tryed didn't help the proublem but that's not to say that that pump was putting out enough flow
