Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
bronco tailgate window help
Old Jul 11, 2009 | 01:27 AM
tbm80's Avatar
Default bronco tailgate window help
I have a 86 bronco that the tailgate windw won't go down. I think it came off the track, was wandering how I could fix it with out taking it to a mechanic and what would be the easiest way to fix it Thanks
Old Feb 6, 2010 | 09:31 PM
87broncofrankinstien's Avatar
Default fix for the rear window
Climb in the back and take off the access panel. there is a switch attached to the door lock for the rear that will get stuck and not allow the window to go up or down. another thing to look in to is unbolting the rear window motor and seeing if it works with out the regulator attached. then check all grounds. the window will not come off track because it is bolted to the regulator and has very little play.
DRock
Oct 10, 2012 07:37 PM
fishfun83
Dec 22, 2010 06:51 AM
luvmy'95bronco
Aug 5, 2010 11:10 PM
mattcw31
Feb 14, 2009 04:03 PM
noonrock
Jan 13, 2009 09:00 AM
