Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
my tires are wasting away HELP
Old Nov 25, 2005 | 01:36 AM
rrubalc's Avatar
Default my tires are wasting away HELP
Im new to the bronco scene and just purchased a 1984 bronco xlt full size with the 302. I have my 15's wrapped in 33" tires yet there wasting away slowly but surely. I took it to get aligned, changed excentric nuts, and also replaced suspension, gear box and yet tires are still cambering out. Any advice to correct this? I know that camber kits are available but dont know which to buy, im getting most of my parts from junkyards (except gearbox) and know that many parts are interchangeable, please let me know if I can find any parts there, any posts are appreciated thanks.
Old Nov 25, 2005 | 04:41 AM
Ramrod48's Avatar
Default RE: my tires are wasting away HELP
what about your radius arms an bushings ??? ,their the the long rods coming off the axle an hook up on the frame just behind the doors ???? , you use to be able to get offset bushings for those, their a special order aftermarket item . An the alignment shop should be able to tell you what degree camber plates to order to set the suspension. I've never seen a Bronco or Full size truck that didnt eat 33", an plan on rotating them alot... Are there any 4X4 shops in your area I would go their instead of the local Joes Car Alignment , as they will normally only be able to advise you on standard car type info
ceadamso
Aug 27, 2008 09:31 AM
stir1404
Aug 7, 2008 10:58 PM
sk8terswife
Jul 14, 2008 07:23 PM
youngstah
May 28, 2008 10:01 PM
AENigma
Jun 7, 2006 03:55 PM
