Need help with chattering noise
I have a 1989 Bronco that when the clutch is pressed in there is no sound, when you release it, it makes a sound like the throw out bearing is bad. Little to say, I removed the transmission and all the parts seem to be new but I went on ahead and replaced everything including the flyweel.
I'm steel getting the chattering noise at idle but when the clutch is pressed down it stops...really could use some advice. actually about to say the heck with it and sell it. but would like to fix it, if someone has had this problem and fairly sure this is what my problem might be. thanks email me at: bikerpawpaw@yahoo.com |
RE: Need help with chattering noise
What trany do you have in it?
