Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Need help with chattering noise
Old Oct 21, 2007 | 04:52 PM
bikerpawpaw's Avatar
Default Need help with chattering noise
I have a 1989 Bronco that when the clutch is pressed in there is no sound, when you release it, it makes a sound like the throw out bearing is bad. Little to say, I removed the transmission and all the parts seem to be new but I went on ahead and replaced everything including the flyweel.
I'm steel getting the chattering noise at idle but when the clutch is pressed down it stops...really could use some advice.
actually about to say the heck with it and sell it. but would like to fix it, if someone has had this problem and fairly sure this is what my problem might be. thanks
email me at: bikerpawpaw@yahoo.com
Old Feb 19, 2008 | 09:16 PM
Superfuss's Avatar
Default RE: Need help with chattering noise
What trany do you have in it?
ec0planet
Dec 25, 2010 09:01 AM
eohdtech
Sep 23, 2010 10:07 AM
randalst
Mar 30, 2010 10:48 PM
KINGDELL
Apr 13, 2008 10:01 AM
hoppy
Jan 15, 2006 01:47 AM
