Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
transmission
Old Mar 5, 2006 | 12:40 AM
jbw1216's Avatar
Default transmission
Anyone know how much transmission fluid is needed when you drain it?
Old Mar 7, 2006 | 01:08 AM
RNGMSTR's Avatar
Default RE: transmission
What year? Are you draining the convertor? Any trans coolers, both factory or aftermarket?
Old Mar 7, 2006 | 11:53 PM
jbw1216's Avatar
Default RE: transmission Ford Bronco
I am just draining the convertor. I had ths done about 6,000 miles ago, but I am getting a slow drip from around the bolts. I was thinking that if I changed the gasket it may stop the drip.
Old Mar 8, 2006 | 01:06 AM
RNGMSTR's Avatar
what bolts are you getting the drip from? What year bronco? Which gasket are you speaking of...pan gasket, rubber grommet on bellhousing...?
