Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Trouble starting 73 Bronco
Old May 3, 2008 | 06:36 PM
fourwheeling73's Avatar
Default Trouble starting 73 Bronco
I have a 73 Ford Bronco with a 302 V8. I put a new starter, and cables on it. I do know that the battery is bad but when i put the charger on it and try to crank itthe silenoid just clicks. the last try i tried it the starter buzzed a little and then the battery charger tried to keep cranking it. It never would start.Has anyone ever had this happen and can you give me some advice.
Old May 4, 2008 | 12:02 AM
Bullitt94's Avatar
Default RE: Trouble starting 73 Bronco
A new battery should give you the juice you need. My '70 came with a bad battery and was difficult to crank. I replaced the battery and it cranked over with no issues.
Old May 4, 2008 | 12:48 PM
thanks, i appreciate your tip. I'm going to give it a try.
Old May 5, 2008 | 12:33 PM
Bullitt94's Avatar
Let us know how it goes.
chad3240
Jan 23, 2015 05:27 PM
Bronco76Ranger00
Nov 8, 2009 08:24 PM
noonrock
Jan 13, 2009 09:00 AM
dlanc88
Dec 16, 2008 12:06 PM
ab1844
Dec 30, 2005 07:55 PM
