Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
98 Contour charging problem
Old Oct 13, 2012 | 08:50 AM
sardonicus's Avatar
Default 98 Contour charging problem
So I took the alternator in to get it tested, and it tested good, and I have a brand new battery in this car, and it just will not charge. What should I be looking at now to troubleshoot this problem? The car has the 2.0L engine in it, just in case that makes a difference.
Old Oct 13, 2012 | 09:24 AM
Some Contours had problems with the alternator and charging system that left a 175 amp mega fuse open and therefore the charge could not get to the battery as designed.
Check that fuse and make sure it is not open.
Old Oct 13, 2012 | 09:33 AM
sardonicus's Avatar
That would be wonderfully simple, I will check on that immediately and post back again if it fixes it. Thank you.
Old Oct 13, 2012 | 09:39 AM
sardonicus's Avatar
I am not seeing anything 175 amp, biggest I see here is 80 amp
Old Oct 13, 2012 | 10:54 AM
sardonicus's Avatar
I just found it, wasnt initially where I thought it would be, thanks again!
Old Dec 2, 2012 | 06:51 PM
davediemer182's Avatar
Where did you find it?
Old Dec 3, 2012 | 06:18 AM
sardonicus's Avatar
I just followed the big wires to this little black box that I had to pry the top off of and the fuse was under there. For some reason I just totally discounted that box as being anything important when I was looking before. Almost impossible to miss when you follow the big wires.
Old Nov 14, 2013 | 08:14 PM
Michel3000's Avatar
Can you tell if this was the problem, the big fuse?
Old Nov 15, 2013 | 10:59 AM
sardonicus's Avatar
Yes - replaced it and poof problem solved
tywebb
Nov 8, 2012 05:25 PM
canuck17
May 16, 2010 03:21 PM
dee004
Apr 2, 2010 04:12 PM
larrybartlett
Feb 11, 2009 02:27 PM
Fredless
Nov 19, 2005 04:26 PM
