Crown vic transmission problems
Old Apr 15, 2018 | 12:31 PM
JFStoltz's Avatar
Default Crown vic transmission problems
I have a 2005 Crown vic sport with 118k miles on it. Over the winter I noticed that it was taking a few seconds for the transmission to engage when shifting from reverse to drive. The trans also has a very slight whine that I can only hear when the radio is off. The fluid and filter has been changed about every 20K since new. Any thoughts?
Old Apr 15, 2018 | 07:10 PM
Has the fluid level been checked to make sure it is correct?
Old Apr 17, 2018 | 09:17 AM
JFStoltz's Avatar
Default Fluid Level
Yes it is full and doesn't leak a drop. It has also been changed since the symptom showed up. I have been using Castrol Mercron V. It is worse when it is cold.
Old Apr 18, 2018 | 07:10 PM
There are certain sealing rings that when pressure is applied a clutch piston moves to compress a series of apply discs and now the power gets transferred out to the output.
When these sealing rings get stiff or leak until they get warm a problem like what your vehicle is showing surfaces. This is only one reason, in my opinion, and may not necessarily be the problem here.
vancouver 95
Mar 9, 2013 11:20 AM
INDA605
Mar 2, 2012 05:25 PM
gnorton52
Oct 3, 2010 07:57 PM
paul morrisino
Jul 14, 2009 04:40 AM
cokehubby
Mar 24, 2008 02:51 PM
