Crown vic troubles
Old Mar 18, 2011 | 06:03 PM
leeval2011's Avatar
Default Crown vic troubles
Hello I own a 2004 crown vic X cop car. At first it had troubles starting and i knew it was the spark plugs as we had not done a tune up in over a year IT IS RUNNING AT 2400 RPM STEADILY. So we changed the spark plugs, wires, intake gasket (which didnt need replacing), did diagnostic and no codes came up, there are no vacuum leaks, and injectors are fine and clean. Compression across the board is great. I hauls!!! Why is it idling SO HIGH. Im afraid its gonna blow. Please help we cant figure this out. Thanks
Old Mar 18, 2011 | 07:08 PM
way2old's Avatar
I might try to clean the IAC valve first to see if it changes the idle.
Old Mar 18, 2011 | 09:05 PM
jdmeaux's Avatar
Default help!
I would suspect the IAC control. When it starts to act up, the idle usually goes up.
gpk9
Dec 17, 2015 03:35 PM
leeval2011
Mar 21, 2011 08:32 AM
semperfi64
Aug 7, 2005 11:54 AM
tored1971
Jun 15, 2005 06:38 PM
penny
Feb 7, 2005 11:30 PM
