Crown Victoria intermittently Overheating
Old Jul 5, 2023 | 02:15 PM
labeeb's Avatar
Default Crown Victoria intermittently Overheating
Hey everyone,
Hopefully, this is the right spot to post about an issue I am facing.
My car was intermittently overheating so I thought maybe the cooling fan module is bad. I checked the voltage on the connector and it was giving me 13 volts, I also checked continuity and it was good to. then I ran a jumper wire directly to the fan and it worked fine. I also changed the thermostat, coolant flush, the water pump is relatively new.
After getting a new fan the car was working fine for a few days then started acting up again. I got a replaced the fan under warranty but that didn't solve the issue.
I noticed the issue happens only during the day, maybe because the weather is hot (118 ℉) which makes the coolant fan module overheat and not work properly?
I also scanned for codes and there's a code "P0480-FF: Cooling fan 1 control circuit malfunction" the codes keeps coming back even if I unplug the fan so not sure if that's a wiring issue
Other thing I looked at is Live data where the "Cooling fan driver fault" fluctuate between No Fault and Yes Fault.
I've attached photos of the fault codes.
Also it might be worth mentioning that the new cooling fan that I got is an aftermarket one and the salesman told me that they've been selling them for a while and they didn't receive any complaint.
Appreciate your help
nwachai
Jun 1, 2021 06:45 AM
Fordowner2356
May 8, 2020 04:22 AM
kubbie
Jul 30, 2012 09:34 PM
pilleway
Feb 28, 2011 10:48 PM
ten8goa
Jul 31, 2006 09:30 AM
