Engine swap
Old May 22, 2011 | 12:35 PM
Jdudley's Avatar
Default Engine swap
I bought a 4.6 engine from a 94 crown vic and was wondering what would have to be swapped for this motor to work in a 2000 crown Vic???
Old May 22, 2011 | 03:31 PM
way2old's Avatar
Intake, sensors, and front cover. The block and internals are the same. Just the bolt on things on the block need changed basicly.
Old May 22, 2011 | 04:05 PM
jessy's Avatar
nice work friend..........
Old May 23, 2011 | 02:11 PM
Jdudley's Avatar
So I can just pull those items off of the engine that is in my car correct????
Old May 23, 2011 | 06:42 PM
way2old's Avatar
Just make sure there is a place to put the sensors and brackets on the other motor. I think the belt is run differently also. If everything bolts up to the front cover, you can use the front cover, if not, it needs to be swapped. Just place the engines side by side and see what needs to be changed over.
Old May 24, 2011 | 10:46 AM
Jdudley's Avatar
Thanks I really appreciate the help....
Old Jun 15, 2011 | 10:26 AM
jessy's Avatar
Owners of BMWs and Mercedes Benz do have some factors in typical: motor vehicle servicing. As high end autos, the automakers are mentioned for equipping their cars with only the finest OEM parts. Properly represented producers utilized by both businesses contain: Bosch, Hella, Mahle, Textar, Brembo, Bilstein, Febi, SKF, and other individuals. Most are German born and bred and therefore are identified the entire world more than for making the greatest quality areas for auto manufacturers..........
bmwrocks03
Apr 21, 2008 09:29 PM
matt95ssei
Apr 5, 2008 02:15 PM
F 150 Bama
Aug 20, 2005 02:06 AM
92FlareSide
Jul 1, 2005 02:30 PM
fordmann67
May 8, 2005 09:22 PM
