hesitation after major tune up
Old Jun 25, 2010 | 11:55 PM
Xxvicman's Avatar
Default hesitation after major tune up
hi, im experiencing hesitation at light throttle between 50-55mph and sometimes at 45 and ive done the following:
replaced spark plugs and coils with motorcraft
replaced fuel filter
cleaned MAF sensor
took it to a trans expert and he said its not the transmission also got a trans filter and fluid replacement
got a catalytic converter restriction test and it was good
i have a P0420 catalytic efficiency code below threshold bank 2 but its been there way before i started having this problem
any advise? thx in advanced!
Old Sep 21, 2019 | 05:37 PM
TheManInDBoX's Avatar
Default Did you ever figure this out?
I know this post is really old, but i just bought a MGM and am having a similar issue..
I get what feels like a miss around 50+mph and it seems to get worse the warmer it gets.
So far..
New Belt, Idler Pulley, tensioner, plugs, coils, water pump, coolant flush, oil change, power steering pump, bearing for the AC, new brakes all the way around, new hardware for the ebrake, new fuel filter, cleaned all the fuel injectors..
I compression tested each cylinder too.. honestly can't figure it out.. It just doesn't appear to be consistent.. was thinking a clogged cat, but i would think that the speed wouldn't make any difference if that was the case..
thanks in advance..
TheManInDBoX
Sep 21, 2019 05:50 PM
Monterey Man
Aug 29, 2013 10:30 AM
hergorilla
Jan 31, 2011 09:18 PM
nirvanachimp
Jul 18, 2010 07:37 AM
wimpy
Aug 19, 2007 09:39 AM
