How to open the AC system for several days?
Old Aug 26, 2013 | 11:00 AM
letsbangout's Avatar
Default How to open the AC system for several days?
Hi all.. 2002 Grand Marquis, 91k miles, I'm still working on a mechanical problem which I outlined in another thread. I believe it's inevitable that I'm going to have to remove the "AC blower box" and all of the AC hoses, in order to continue working around the engine, and to troubleshoot an electrical problem along the cable that runs through the firewall under the AC box. My plan is to suck out the freon into a tank at low pressure, and disconnect the hoses leading to and from the evaporator.
What's the best way to safely preserve all of the components that'll be disconnected, for a few days while I'm working around the engine? Can I just stick a shop towel over the hoses/openings/etc. held on by maybe a rubber band? Secondarily, while I have the system open, I recall reading that one of the hoses has a tendency to develop corrosion over time and should be replaced.. what's the consensus on maintenance-type work that should be done while the system is open? I was only planning on either flusing the corrosion-prone hose, or replacing it, once I figure out which it is.. and maybe a new set of O-rings all around. Anything else?
Thanks in advance.
pghstlrs01
Oct 1, 2022 06:14 AM
Old4xford
Feb 27, 2012 05:16 PM
dj_mindframe_99
Jul 12, 2009 03:35 PM
tushar
Jun 15, 2006 03:34 PM
