protective coating on throttle body plate.
Old Feb 2, 2008 | 04:09 PM
97CVPI's Avatar
Default protective coating on throttle body plate.
Hey, i have a 1997 crown victoria P71 and i was wondering if spraying throttle body cleaner in the throttle body and on the plate will affect anything,because there was a Attention sticker saying not to use cleaner because of some coating on the throttle body plate. I saw this sticker after i had already sprayed the throttle body. Does anyone know?
Old Feb 2, 2008 | 07:47 PM
way2old's Avatar
Default RE: protective coating on throttle body plate.
You are more than likely safe if you sprayed throttle body cleaner and not carburetor cleaner. In 97, carb cleaner was the only spray cleaner widely available and it would remove the coating disturbing the air flow.
Old Feb 10, 2008 | 07:55 PM
pollenjesus's Avatar
What is the protective coating made of. I sprayed my 2003 throttlebody with brake cleaner back in the summer to clean it up, and ever since then it whistles. Does the protctive coating have and performance benefits? I added a throttlebody spacer the next week which whistles anyway. I like the sound of the whistle...kinda sounds like a turbo.
Old Mar 6, 2008 | 03:04 AM
goinstrong's Avatar
The coating helps control and smooth intake air flow. Can make a difference.
Spaznaut
Jun 1, 2014 06:47 AM
makuloco2000
Jan 17, 2014 07:06 AM
WV-F150-4.2L
Mar 16, 2011 06:34 PM
91EXPLORER
Feb 20, 2006 01:07 AM
dngrrngr93
Aug 26, 2005 05:53 PM
