spindle and caliper options
Old Sep 2, 2012 | 11:02 PM
Wheelgun's Avatar
Default spindle and caliper options
i have an 05 crown vic front suspension clip in my daughters 67 f 100. what if any spindles and calipers can i use so i can run 15 in rims.?
thanks in advance
Old Sep 3, 2012 | 09:07 AM
bandit1948's Avatar
you don,t need to change the calipers and spindle to run 15 inch wheels ! all you have to be concerned about is the bolt pattern and if the center hole on the rim will fit over the hub !
Old Sep 3, 2012 | 01:37 PM
Wheelgun's Avatar
This suspension clip is from an 05 police car and has the big brake package. Right now the minimum rim size that will clear the calipers and spindles are 16's. I dont much care for the looks of any 16 in rims and already have a set of new torque thrust rims for all four corners. I was wondering if spindle and caliper assemblies from perhaps a standard Vic or Marquis might run smaller diameter wheels
79ranchero
Jun 4, 2013 01:28 PM
darrall
Oct 24, 2009 01:25 PM
treetopp87
Mar 28, 2007 07:33 PM
lauk101
Oct 4, 2006 08:54 AM
redskins13
Sep 9, 2006 06:07 PM
